PCIe pld_clk conflicting coreclkout statements
- 2 years ago
Hi @corestar,
Thanks for sharing your objective.
My apologies for the delayed response, I took some time to gather the information.
In this case, it is suggested that you drive the pld_clk with coreclkout_hip, as using a single clock simplifies timing.
In the situation that you wish to drive the pld_clk with an other clock source, the following clock frequencies of the clock source could be used:
1.When coreclkout_hip is 62.5 MHz:
Try to use 125 MHz, or 250 MHz.
2. When coreclkout_hip is 125 MHz:
Try to use 250 MHz.
Please note that not all frequencies of other clock source within the specified range can be used to drive the pld_clk.
VenTingT
Hi @corestar,
Thanks for reaching out.
Allow me some time to investigate your issue. I shall come back to you with findings.
VenTingT
