13 years agoPCIe PIO Beginner Questions
I've been pouring over the documenation, examples, and forums for information on PCie HIP implementation and I'm still really struggling here so I'm hoping someone can help me in my first battle with...
13 years agoDave,
Thanks for the quick reply, and for your incredibly explicit directions in the pdf. I feel a bit like an idiot asking more of you but, I did get stuck in your directions very close to the end at the "Source Contraints" step. I found the .tcl file, but I'm not sure how to source it and I assume once I do that successfully the following line of code will work, but at the moment it does not for me. I also tried your autogeneration thing, but quartus 12.1 threw a bit of a fit. I would rather step through it instead of auto-generating though, so I'm more interested in what you meant about those constraints. Some comments I noticed: Everything I've seen always has a DMA block connected to the pcie block. Since my data transfers are relatively basic, I was wondering if that was really necessary (I've read DMA has a large overhead, and so is not efficent for small amounts of data). From a curiosity standpoint, is there a way to configure this thing without having to use the host PC? Isn't there a way to find the PCIe addresses without just finding it on the host PC? I thought my idea of polling the physical addresses wasn't the worst thing... And as a more general question, is the purpose of this whole thing to have something like a PCIe block that just has a more basic interface (tx/rx) kind of thing to be used in other designs? Thanks so much for your help thus far, Craig
