11 years agoPCIe MSI interrupt sharing problem
Hi, MSI shared for DMA Read and Write. In ISR() routine, checks status to determine read or write completion. Either there is missing MSI or Read completion MSI can be mistaking as Write comple...
11 years agoThank TCWorld,
First, this is a edited version of ISR() for easy to read. So I removed some unnecessary lines of code. FDO obj is obtained on the first line of the routine: FdoData = FdoGetData(WdfInterruptGetDevice(Interrupt)); sorry for misleading. Let me modify as you instructed. let you know the results. Thank you
