11 years agoPCIe MSI interrupt sharing problem
Hi, MSI shared for DMA Read and Write. In ISR() routine, checks status to determine read or write completion. Either there is missing MSI or Read completion MSI can be mistaking as Write comple...
11 years agoMy crystal ball says there is an issue with line 42 of your code.... That's about as helpful as I can be with the information you have provided.
Is this Windows? Linux? Something Else? What is in your interrupt routine?
