14 years agoPCIe Memory Write Transaction
Hi, I am facing an issue while performing memory write transaction with payload more than 128Bytes from root to endpoint. Write transaction with less than 128Bytes are completed easily. I have ...
14 years agoI think there is a configuration space register that is needed to be programmed otherwise i saw the endpoint example that is generated by megafunction. In their example endpoint is performing much larger memory write transactions.
