12 years agoPCIe Legacy Interrupts Not Happening
I have a Cyclone V design built with Qsys (Quartus II 13.0 SP1). The Qsys module has an Avalon-MM bus, a C5 HIP PCIe core and some other blocks connected to PCIe BARs (all 32-bit non-prefetch). The P...
12 years ago --- Quote Start --- Legacy interrupts are running now. There was a problem with the value of a parameter called "CG_ENABLE_ADVANCED_INTERRUPT" in one of the Qsys generated files. It's still being investigated by Altera but I thought I throw a clue :-) in case somebody else has similar problems. --- Quote End --- Hello, It seems to me that I have the similar problem, I can not see generation of legacy interrupts on my host PC. Do you have any details -> what did you need to change to enable legacy interrupts for you ? Could you please share your solution ? Thank you. Lukas
