17 years agoPCIe IP target->host MRd but no completion
Hello, I am using the PCIe IP (9.0). I recieve posted and non-posted TLPs from the host (PC) and send completion TLPs back and everything works great. However, when I initiate an MRd from...
17 years agoI opened a ticket with Altera. They want me to check my design and run it in a testbench. I think I will do that and see. It is weird though since everything else works. Even MRw TLPs from the target to the host work fine. What I am wondering is if the logic that is responsible for asserting the rx_req is different depending on whether the rx_desc from the host is a completion rather than a new TLP. If that is the case, then there could be a possibility that something is getting optimized out...
