10 years agoPCIe IO BAR's limited to "Legacy Endpoints"
I am looking to define an EP with a BAR defined as IO instead of memory inorder to test the IO / CNFG PCI ordering rules . I thought it would be as easy as going into an existing design and r...
10 years ago --- Quote Start --- IO style endpoints aren't really supported in PCIe. They only exist so that legacy PCI cards can be attached via a PCIe to PCI bridge. I wouldn't be at all surprised to find out they don't work. I wouldn't be upset about it either. It's basically legacy garbage that should be ignored in a modern design. --- Quote End --- Thanks Galfonz. I'm not particularly interested in IO and understand the point you make but I am interested in testing ordering rules for IO and Configuration Writes / Reads per the specified rules since IO and Configuration are handled differently ... Since IO and Configuration are treated the same with respect to ordering , I thought IO would be easier to implement. If it is't easy to implement with the hard PCIe IP I have access to ... then I will look to the Keysight and LeCroy Exerciser cards that I have access to.
