PCIe Hard IP Cyclone 10 GX is not Detect in PC
Hi Jan,
The above problem is occured due to , you did not configure the PCIe IP correctly . May be the PCIe is in reset state.
Can you please provide the LTSSM state signal tap for my reference.
- JKoty6 years ago
I was able to scan status of basic signals some times after start. I am not sure how to trigger initial sequence for PCIe (If it is necessary for you) because Signaltap load image/ power cycle delay and so on... but for now it is looks like PCIe is stuck in state 03h - polling.compliance state
This design is reference design :
https://www.intel.com/content/www/us/en/programmable/documentation/ecx1522703736467.html, https://fpgacloud.intel.com/devstore/platform/2183/
So pins and others project depend settings should be done correctly, but I can share with you some post build logs.
Quartus only ask me for update IP core:
But I do not thing that is really important for detecting PCIe in PC - what is my goal for now.
Best Regards
Jan
