16 years agoPCIe freezing
Hi, I have strange problem with PCIe IP. I have a custom board with ArriaGX and PCIe instantiated using MegaCore flow with AvalonST interface. The PCIe works (there are some DMAs running, targe...
16 years agoMartin,
even if you don’t have to transmit anything I would suggest that you at least design a detector to see whether any unsupported request is handed over on the rx port. Those requiring a completion should be properly managed by your design, even in the cut-down minimum debugging version. I hope your configuration registers are in a non-prefetchable BAR. Another issue could be the PC driver. Are you sure the hangups are not a driver’s fault?
