11 years agoPCIe-Ethernet Bridge help
Hi! I am working with Arria V GT and want to make standard Ethernet controller like Intel 82599. So, i have correct PCS block (tested) and want to use 2 IP cores - Avalon MM DMA for PCI Expre...
11 years agoHi,
We are also working on similar type of design on Cycleon V FPGA Board to access SD Card through our custom SDHC Host Controller which has one DMA Controller for PCIe-SD Bridge Inteface. Now, I want to read/write data from/to SD Card through my Linux PCie Driver using Chaining DMA. Do I need to connect DMA Read & Write Master Port to one of BAR region from FPGA design to read/write data on SD Card from Linux System? or Can I Directly use DMA without assigning into any BAR Region? Please let me know if anyone has idea about that. Regards, Ritesh Prajapati
