11 years agoPCIe Driver
Hi everybody, I`m new on this forum and in the usage of Altera product, then be patients please. I`m not able to find the answer to my questions. I want read and write from my FPGA (Stratix V) ...
11 years agoHi everybody,
I have solved my problem on Windows using the Riffa interface. Now I`m working on Linux I have found this example: http://www.alterawiki.com/wiki/reference_design:_gen3_x8_avmm_256-bit_dma_for_external_ddr3_-_stratix_v I have downloaded the Linux Driver and I would like use these drivers to write a linux application. I'm looking for a framework for communicating data from a host CPU to a STRATIX V via a PCI Express bus with bindings for C/C++ that supports Linux. My problem is that I can not find any documentation or the API to use these drivers. Someone knows if are there some documentation or the API for these driver? Or are there some equivalent example for the StratixV with the working linux drivers (with documentation and API)?
