16 years agoPCIe core MSI-X support
I have added MSI-X support to an implementation of the Altera PCIe core we're already testing in the lab. My understanding, is that with MSI-X enabled in the megawizard and my vector table offset se...
14 years ago --- Quote Start --- Yes, either the first one (if addr mod 8 == 4) or the second one (if addr mod 8 == 0). --- Quote End --- I made in this way... but problem was that in 2clk packet I send Clk2: PCIe_data_out [63:0]<= {msix_Msg_Lower_Addr[msix_Number], Sig_Packet_Data_field [31:0]} but should be Clk2: PCIe_data_out [63:0]<= {Sig_Packet_Data_field [31:0],msix_Msg_Lower_Addr[msix_Number]} Thank You for help!!!! :) Now everything is ok. P.S. 1st PC understand write packet with 64 bit addr even if upper addr is all 0... but other don't understand... (they understand just 32bit addr packets)
