14 years agoPCIe core LTSSM signals
Hi guys, I've observed some "weird" issue today. I'm pulling Test_out[4:0] out to my Logic so that I can read them as system status. When I do that I have intermittent link training issue. D...
13 years ago --- Quote Start --- Hi, Thanks, is it in the PCIE HIP verilog codes? Regards, --- Quote End --- I'm not sure where exactly. https://www.alteraforum.com/forum/attachment.php?attachmentid=7523 https://www.alteraforum.com/forum/attachment.php?attachmentid=7524 I can't confirm that you have the same issue. But here are the signals. Look at the last signals in the 2 waveforms. The states variable: ...|calibration|state Bad case: the state register goes into some wierd value, everything just stuck there Good case: the controller move on after reset is released. You can trace that signal
