14 years agoPCIe core LTSSM signals
Hi guys, I've observed some "weird" issue today. I'm pulling Test_out[4:0] out to my Logic so that I can read them as system status. When I do that I have intermittent link training issue. D...
13 years ago --- Quote Start --- Hi, Are you able to solve your intermittent issue? Also using Arria II device. I have similar intermittent ltssm issue during power-on. Regards --- Quote End --- Mine was an issue caused by the Reset controller in the Reference design. The reset controller has a statemachine which is asynchrnously reset by a signal fed directly from PLL's lock --> The statemachine goes to unknown state sometimes and the HIP can't be initialized properly. Exactly where I can't recall. Please trace it first if you still can't find it, I may need to dig up the code. Remember, reset controller, PLL's lock signal --> Resolved by a simple synchronization of Reset to the clock domain.
