14 years agoyeah i think the problem is the root bar addresses are not programmed correctly and also the base memory and limit registers. I recommend you to check the simulation of root port that megafunction generates. In that simulation you can see the mandatory registers program before the mem transactions. Also check the command register of endpoint and rootport are programmed correctly or not
