14 years agoPCIe bus master random access to all host memory
I'm not sure if the PCI Express MegaCore hard IP can do what I want. I'll describe what I'm trying to achieve. I'd like to set up a bus-master scatter-gather DMA between on-device memory and a ...
11 years agoI'm now trying to get this to work, and of course it doesn't.
I don't need high throughput but do need long TLPs (read and write) and asynchronous operation (controlled by a nios cpu). The 'simple' DMA controller ought to work, but when I request a transfer all that happens is the 'BUSY' bit in the status register is set. Unfortunately it is a bit difficult to connect the JTAG port to the board I'm using, making signaltap unusable. It might just be that I've configured the DMA controller incorrectly (in sopc). I haven't found any info into the required parameters for PCIe DMA. I decided that the 'best bet' was to 'enable burst transfers' and I set the 'maximum burst size' to 128. There is some strange comment in the documentation that the maximum transfers length must be less than the maximum burst length - is this really true? The longest transfer I need to do is 0x120 bytes, most will be shorter. Possibly I should be enabling (and using) 64bit transfers? Any ideas what I've done wrong? The SGDMA is overcomplex for what I need.
