14 years agoPCIe bus master random access to all host memory
I'm not sure if the PCI Express MegaCore hard IP can do what I want. I'll describe what I'm trying to achieve. I'd like to set up a bus-master scatter-gather DMA between on-device memory and a ...
13 years agoIP Compiler for PCI Express generates the Avalon slave 'tsx' port with txs_burstcount[6..0] - this suggests bursts of up to 64 cycles * 64bits data width = 512 bytes (128 DW) which is a reasonable size for a burst TLP. With this port the TLP headers can be correctly set ahead of payload transmission.
Since the Core uses a fixed hardware buffer for retransmission, with fixed 'pages' for each TLP (rather than circular buffer) there is a payload limit for packets of either 256 bytes or 128 bytes. So certain values of the txs_burstcount imply packets too big to buffer, with 256 bytes limit would be 64DW or 32 burst cycles. Given the Altera DMA controller uses this same HW port to do it's DMA writes you should be able to get at same performance writing to that port yourself without resorting to the streaming interface. Using the streaming interface I doubt you can exceed 64DW as you need retransmission support.
