14 years agoPCIe bus master random access to all host memory
I'm not sure if the PCI Express MegaCore hard IP can do what I want. I'll describe what I'm trying to achieve. I'd like to set up a bus-master scatter-gather DMA between on-device memory and a ...
14 years agoQuoting last two posts (different authors):
--- Quote Start --- The above is just my understanding and may be partly or completely wrong. --- Quote End --- I think you are quite right there. --- Quote Start --- This can only really be done if the DMA controller in integrated into the PCIe master logic. --- Quote End --- There are a lot of optimizations and removal of limitations if the SGDMA controller is integrated in the PCIe master logic. Arbitrary access to 64-bit host memory is just one thing. --- Quote Start --- ... I'm interested in how the Lancero solution compares to the Altera offerings. --- Quote End --- I don't think this forum is meant to discuss Altera Partner IP, so I consider to look at its web page and ask.
