14 years agoPCIe bus master random access to all host memory
I'm not sure if the PCI Express MegaCore hard IP can do what I want. I'll describe what I'm trying to achieve. I'd like to set up a bus-master scatter-gather DMA between on-device memory and a ...
14 years agoHmmm..... I'd have thought that the DMA controller would be able to pass a full 32bit PCIe-space address, rather than an Avalon MM slave address of the PCIe controller.
This partially important because you need the PCIe controller to issue single PCIe requests for large blocks (say 128 bytes min) in order to get reasonable throughput - which is likely to mean that you need to use a DMA controller embedded into the PCIe interface. (That is what we had to do on the pcc when the fpga was a slave...)
