16 years agoPCIe and Nios in SOPC builder
Hallo all, I'm trying to build a system with two DMAs PCIe compiler and Nios as a DMAs controller. I'm reading DMA descriptor from host (using the Tx PCIe interface) config the DMA Rx and DMA ...
16 years agoI successes now to transfer burst.
But because my host is 64bit and the avalon is 32bit, I needed to connect read and write to tx_interface at the PCIe core(I added unnecessary arbitration on both interface!) That the only way it's work - did you handle anything similar? Thanks.
