16 years agoPCI Express Tx interface gets stalled
Hi, I'm still trying to send data (A/D samples) from my PCI Express endpoint (S4 GX Dev. Kit. -> Hard IP) to the root port memory (RAM). I'm able to receive data from the root port, and also...
16 years agoThe key is that the waveform in figure 5-14 applies to 3 Dword header TLPs with NON-Qword aligned addresses. There is a comment about this in the text immediately above the waveform. This comment implies the address restriction I mentioned in the previous post. I hope this helps.
