16 years agoPCI Express Tx interface gets stalled
Hi, I'm still trying to send data (A/D samples) from my PCI Express endpoint (S4 GX Dev. Kit. -> Hard IP) to the root port memory (RAM). I'm able to receive data from the root port, and also...
16 years agoI'm aware that the payload length field in the header contains just the amount of payload DWORDs, and not also the header.
I Just wanted to point out that I'm using a 3 DW header (because my destination memory addr. is 32 bits), and this results in an odd number of payload DWORDs (since the 2nd QWORD [I'm using Avalon-St interface with 64 bits] contains the 3rd DWORD of the header and also the 1st DWORD of the payload). @ (1): the alignment of my payload data looks exactly like in figure 5-14 on page 5-15 of the user guide @ (2): I'm using 64 bit Avalon-St interface Is it possible to determine the root ports status from the endpoing e.g. by reading the "PCI Express Advanced Error Reporting Capability Structure"? edit: uploaded the waveforms captured with signaltap to http://rapidshare.com/files/376204701/datagrabber.vwf
