15 years agoPCI Express to External Memory Reference Design Qsys(Arria II GX): Data Verify Failed
Hi I am trying to run the reference design with the guide of an433.pdf. In the PCI Express Demo Application, When i select the run Onchip DMA Test or DDR DMA Test with the following set...
15 years agoSounds like it was just issue with loose connection? based on what the woeichee said?
