15 years agoPCI Express to External Memory Reference Design Qsys(Arria II GX): Data Verify Failed
Hi I am trying to run the reference design with the guide of an433.pdf. In the PCI Express Demo Application, When i select the run Onchip DMA Test or DDR DMA Test with the following set...
15 years agoI believe it shouldn't related to the slot where you inserted. I've tried using the x16 slot but no trouble.
Was the board detected correctly on the GUI? The other direction worked for you? sounds like you are having issue on the PC to FPGA direction only?
