13 years agoPCI express Stratix IV implementation
Hi there, I'm using a Stratix IV GX and i want to use the PCI express link to transmit data from my FPGA to another one. The data which have to be sent are generated by a personnal IP and no ...
13 years agoHey tricky,
Thanks for your reply i take your advice but if it's possible i'd rather not use the avalon bus.:) Yes i went trought the user guide, and i have seen that a "descriptor/data" can be configured instead of the avalon interface. It may be my solution don't you think ? I have generated the vhdl files of the PCIexpress Soft IP using this "descriptor/data" with Mega Wizard and now i'm looking at all the I/O signals of this IP. I supposed that i have to link a lot of them and not only "tx_data, tx_desc, rx_data, rx_desc", what do you think ? But by the way, i had to configure BAR registers in mega wizard but i don't think that i need them since i don't want to work with any "memory location". Thank you for any advice. Best, Alexis
