18 years agoPCI Express SOPC flow hardware ready example with README
When I tried PCI E SOPC flow for the first time, I got stuck a little bit. So I put some tips for the SOPC flow in the README file. Hope the combination of README and example will help someone g...
16 years agohello:
I downloaded your files and did some simulation in modelsim-altera6.5.First I built an sopc system including DMA Control,On Chip memory(RAM) and PCI Express.My quartus version is 9.1.Then I run the testbentch provided in the project folder.The result is in the attachement,I think the result is not correct. I don't understand why the value of DMA signal "length" is always"000000",and the simulation result is also run out of control,Can anyone figure out the reason?
