18 years agoPCI Express SOPC flow hardware ready example with README
When I tried PCI E SOPC flow for the first time, I got stuck a little bit. So I put some tips for the SOPC flow in the README file. Hope the combination of README and example will help someone g...
16 years agoHi Mohammad,
I will take one step back and try to use the Avalon verification suite (Quartus 9.1). you can add to your SOPC system Avalon BFMs and Avalon Monitors. I believe that this will be a good start point - verifying you Avalon MM components. and for this you don't need the PCIe core. later when you sure that your component are well covers you try using the PCIe VMM. Hope that I help a bit? Regards, Tal.
