18 years agoPCI Express SOPC flow hardware ready example with README
When I tried PCI E SOPC flow for the first time, I got stuck a little bit. So I put some tips for the SOPC flow in the README file. Hope the combination of README and example will help someone g...
16 years agoDear Andy !
thank you for your answer ! At present I do not understand why my project SOPC PCIexpress for Stratix II GX board work with Altera driver and simple_dma.exe or pcie.exe, but not work with my WinXP application with I create with help jungo win driver library. I have create my Altera Stratix progect following AN532, complile, make pof, sof files, programm flash memory on board. After then use windriver_811 progect from Altera arhive (AN532_PCIe_sopc_s2gx_x4). And all work good ! But my own application - is in state of nonoperability. I want look small small small example witch work with board in contig.DMA mode. thank very much !!!! Vladimir
