12 years agoPCI Express IP Hard core reference clk
Hi, I'm implementing PCI Express in Cyclone 5 GX and I have a question - I'm using lane 0 therefore TX and RX are connected to GXB_RX_L0 and GXB_TX_L0, but due to the pcb routing I can't connec...
12 years agoI wouldn't expect to see anything further from L0 until the operating system on the Keystone probes the PCIe bus to enumerate devices. Do you have e.g. a Linux install and access to /sbin/lspci or similar? The device should show up as enumerated with the device/vendor codes you specified in the core. Actually generating read/write transactions from the host requires you either write a device driver or use Dave's excellent PCI pci_debug tool to access the bar memory space via. /sys/ filesystem.
It's in the zip file you can download from Dave's post, needs a c compiler and make on the host. http://www.alteraforum.com/forum/showthread.php?t=35678
