18 years agoPCI Express - chaining DMA - newbie Q
hello, i'm stuck (rather newbie) and would like to ask if i'm taking the right approach. i used the pci express compiler user guide 8.0 using the megawizard to create a pci express soft ...
18 years agoNot sure what is wrong. PCIE_example_chaining_top.vhd should be the top level file for the design. I have never tried making and using a .bdf file before.
What happens if you open and compile the PCIE_example_chaining_top.qpf project file? That should give you the complete design. You should be able to just make the pin assignments for your board in this project.
