14 years ago
PCI-E gen3 HIP simulation
Hi
I am having some trouble while simulating the PCI-E gen3 design. As mentioned in the User guide.
1. I ran modelsim
2. source msim_setup.tcl
3. ld
while compiling the files modelsim shows the following errors:
1. faild to open info file "/_info" in read mode
2. Module 'stratix_hssi_gen3_pcie_hip' is not defined
I generated pcie files using Quartus 12 and i am using modelsim 10.1
    I believe you have to use Q12.0sp1
    Q12.0 still doesn't have BFM in.
    I am also facing the same problem with Quartus 12.0 sp1.
    For the ip generated through megawizard for verilog, I ran vsim in the <ep>_sim/mentor directory
    source msim_setup.tcl in vsim
    ld_debug
    and I see simulation exiting with errors like
    instantiation of stratixiv_hssi_gen3_tx_pcs_encrypted failed. The design unit was not found.
    where can find this module?
    Alternately, I generated vhdl version of the PCIe core gen 3 and executing the same command ld_debug yielded this error.
    Fatal error in a protected context.
    Time 0 ps Iteration Protected: /ep_g3_x8_avl_256_a_s5_inst/<protected> File: nofile
    FATAL ERROR while loading design
    Any ideas/solutions about VHDL simulation failure would be highly appreciated.
    Fasahat
