14 years agoPCI-E gen3 HIP simulation
Hi I am having some trouble while simulating the PCI-E gen3 design. As mentioned in the User guide. 1. I ran modelsim 2. source msim_setup.tcl 3. ld while compiling the files mode...
13 years agoI am also facing the same problem with Quartus 12.0 sp1.
For the ip generated through megawizard for verilog, I ran vsim in the <ep>_sim/mentor directory source msim_setup.tcl in vsim ld_debug and I see simulation exiting with errors like instantiation of stratixiv_hssi_gen3_tx_pcs_encrypted failed. The design unit was not found. where can find this module? Alternately, I generated vhdl version of the PCIe core gen 3 and executing the same command ld_debug yielded this error. Fatal error in a protected context. Time 0 ps Iteration Protected: /ep_g3_x8_avl_256_a_s5_inst/<protected> File: nofile FATAL ERROR while loading design Any ideas/solutions about VHDL simulation failure would be highly appreciated. Thanks, Fasahat
