12 years agoPCI Avalon-MM Multi-master arbitration
Hi, I want to do a qsys system with two "Avalon-MM Stratix V Hard IP for PCI Express" which need to access the same Avalon-MM slave. Anyone know a solution for the arbiter between those tw...
12 years agoHi, thanks for your answer. If I connect both master avalon bus port to my slave, what about the clock? My slave requires a clk_in and a reset source. Can I feed any free running clock to that slave and the avalon fabric will insert buffer?
