10 years agoPause needed between multiple DMA transfers?
I try to sequentially read buffers from PIO at the fastest possible speed with NIOS II/f. Everything works fine, however the speed seems to be limited to ~25 MB/s, independently of the buffer si...
10 years agoYour description sounds like you have a bug in your done() callback and rx_done handshake. For example, you might get the behavior you described if you had never reset rx_done back to zero before starting the next transfer.
