15 years agoPassing channel to Avalon-ST demultiplexer
Hello, I am trying to build a component, which will be connected to Avalon-ST demultiplexer. Since the data has to be switched between inputs, I've added aso_channel signal. The SOPC builder compl...
14 years agoYep that's correct. It's present in .tcl instead of being directly derived from the width of the channel signal so that you can limit the number of channels. Otherwise you would be stuck with 2, 4, 8, 16, 32, 64, etc... channels.
