15 years agoPassing channel to Avalon-ST demultiplexer
Hello, I am trying to build a component, which will be connected to Avalon-ST demultiplexer. Since the data has to be switched between inputs, I've added aso_channel signal. The SOPC builder compl...
15 years agoi think max channel is derived from the width (or presence) of a channel signal on an ST block, so it has to be an actual port to your module
