11 years agoParallel Flash Loader PFL: What CFI IDs for Spansion S29WS256P?
Greetings, I have a custom board with Cyclone-V and Max-V 5M1270 plus a Spansion S29WS256P 16b NOR flash, the Max-V sits between the FPGA's configuration pins and the flash memory. I would ...
10 years ago --- Quote Start --- Solved: I inadvertently had the AVD# pin pulled up instead of down, so the PFL could not set any addresses on the device (AVD# 'address valid' is not a PFL pin). With that fixed I find that the S29WS256P is already defined in the PFL / progammer tool, no custom CFI device needed. The PFL can now happily write & verify my device. Now to get it to configure the FPGA... --- Quote End --- my english is bad, but i have the same problem, you anwser may help me, so thank you very much.
