8 years agoParallel Flash Loader (PFL) IP Core Timing Constrains
Hallo Everyone I am making a Parallel Flash Loader (PFL) IP core for MAX V device. I have some problems in constraining the design with the timing. In the following link it is mentioned that ...
8 years agothanks a lot for your reply. This solves the problem. So if i understood you correctly
output false paths should be set with the command set_false_path -to input false paths should be set with the command set_false_path -from I tried this two command on my input and output ports false paths and it works.
