8 years agoParallel Flash Loader (PFL) IP Core Timing Constrains
Hallo Everyone I am making a Parallel Flash Loader (PFL) IP core for MAX V device. I have some problems in constraining the design with the timing. In the following link it is mentioned that ...
8 years agoI don't understand why you're doing this:
set_false_path -from [get_clocks *] -to [get_ports {flash_nce}] It should be simply: set_false_path -to [get_ports {flash_nce}] Same with all your output false paths.
