15 years agooutput source synchronic clk using altlvds
I want to use altlvds like this: use 4:1 altlvds output serial data,in order to output source synchronic clk,i use anothers 4:1 altlvds to sample input clk,Is this a right way?I know that the clk ...
15 years agoThe serializer that sends out the clock shouldn't be sampling the clock. Just tie off the 4 inputs to 1010 and you will send out a clock alongside your data. That should very nicely match your data output and you should have good timing.
