12 years agoOutput Latency for Integer Arithmetic Megacore at Cyclon Family
I do not know what Output Latencies are valid for a Cyclon V Device for the Interger Arithmetic Megacore Functions, so I used the worst case values I found in the User Guide for pipelining the functi...
12 years ago --- Quote Start --- I do not know what Output Latencies are valid for a Cyclon V Device for the Interger Arithmetic Megacore Functions, so I used the worst case values I found in the User Guide for pipelining the functions. Has anybody some hints, how I can find out the correct / optimized values for the Cyclon Family? --- Quote End --- pipelining the core is not matter specific to a device. You have options of pipeline from 0 to whatever and you choose whatever helps your design achieve speed. If you start with a pipeline of 1 and it failed timing at the core then go up to 2 and so on.
