11 years agoOpen Core Evaluation Time
I am using CIC and NCO MegaCores. In warning messages, it is stated that IPs will stop working after 1 hour of programming the device. However, when I program the device with "_time_limited.sof" bit file, a window popups and says that "Time Remaining: Unlimited". How can I understand this inconsistency? And if it is NOT unlimited, how can I check the remaining time for each IP? Thanks in advance.1 Reply
Hi Siraj,
I think you should place Service Request via myAltera account on Altera's website. You are likely to get correct answer from there since this IP is property of Altera and that team shall be able to help you. Cheers, Bhaumik
