11 years agoOnchip RAM Corrupted by Reset
Hi, I currently have a large system that I have been developing for the last year or so. Until now I have been uploading a sof file to the FPGA, and then using eclipse to upload Nios code to an...
11 years agoWhen you reset a DDR memory controller it stops refreshing the memory. Thus the memory content is lost. If you re-initialize the memory controller quickly it is possible that not all memory cells are lost. Thus your observed memory corruption. If you wish to preserve DDR content over a soft reset, you need to configure your system so that the hardware does not reset the memory controller on a soft reset and the software does not re-initialize it when doing a soft boot.
Depending on how your board is wired it may not be possible to prevent the FPGA being re-configured when the PC reboots. If this happens, you will also loose DDR.
