15 years agoon-chip memory timing diagram
Hi I need have to continuosly update sections of an onchip memory on a regular basis as quickly as possible. I'm using a 125MHz clock. My problem is the datasheet of the onchip MF is quite vague on t...
15 years agoAdditionally,
use registers at input/output/address. they are there at no extra cost. Many designers add a further register between block outputs and logic fabric to improve speed across...
