9 years agoOff by 1 error with Altera SRAM controller IP?
I have a Nios II system running on a DE2-115 that is connected to both the DRAM and SRAM on board. I have written a VGA driver that uses the avalon bus to fetch pixel data from either DRAM or SRAM, d...
9 years agoWhat does the full path show in Timequest? It should show you all the hops between the from_node and the to_node. A recovery timing failure means that an asynchronous signal is arriving too late to the latch destination. The full path might show why the launching address has an asynchronous path to the output of the FIFO RAM. I suspect the full path will look something like this: fbAddr[7] --> Qsys decode logic --> rdreq of DCFIFO --> q_b[0] but I'm not sure why DCFIFO would have an asynchronous load/set/reset in this case dependent on the read request coming at it though.
Did you recompile the design after making the timing changes? If not I would close the Quartus project, delete the /db directories, then recompile because it could be that the fitter spent so much time fixing a setup issue that it introduced recovery failures and re-running the fitter might fix that.
