9 years agoOff by 1 error with Altera SRAM controller IP?
I have a Nios II system running on a DE2-115 that is connected to both the DRAM and SRAM on board. I have written a VGA driver that uses the avalon bus to fetch pixel data from either DRAM or SRAM, d...
9 years agoHave you tried memory testing the SRAM using Nios by itself? It almost sounds like the off-chip timings are incorrect and you are reading data too late.
