17 years agoOFDM using DSP Builder
Hi, I'm trying to implement a simplistic (4 channel) QPSK OFDM transmitter/receiver using Altera's DSP Builder and Megacore IP in Simulink. Let me just mention that I have very basic knowl...
17 years agoHi,
I agree with OD about the idea of full dynamic range and in that case you can scale to +127 & -127 for 8 bits. However, in actual systems with possibility of other modulation schemes e.g. QAM then you need to normalise all the levels to get unitary power. For QPSK the .707 per I/Q gives a unitary power as I^2+Q^2 = 1 edit: if power levels are different in the final signal, you are likely to have a lot of head butting with the RF engineer especially so with ofdm as peak/average power is very high. Kaz
