17 years agoOFDM using DSP Builder
Hi, I'm trying to implement a simplistic (4 channel) QPSK OFDM transmitter/receiver using Altera's DSP Builder and Megacore IP in Simulink. Let me just mention that I have very basic knowl...
17 years agoHi,
I don't use DSP builder(& I don't know anybody using it in the industry, only saw the party here!). If data precision is 24 for either Im/Re then it is more than enough. I believe by "streaming fft" altera means a continous output though processing is block based. I can use two fft cores swapping the processing resulting in continuous output but after initial delay. You can control this double processing yourself without the need for avalon hand.
