11 years agoNo output data of CVI IP core.
Hi guys, First off, I just started using FPGAs about a month ago, and am only just beginning to use Nios II and IP Cores, so suffice to say I am very new to this. I'm working with CVI IP c...
8 years agoHey Guys,
I am also seeing the similar issue. I do not see any output on the CVI block. I have signal tapped and verified the input to the CVI block and input seems to be fine. Any inputs? Regards, Hanumanth
